I just did a complete reset of the radio this morning.
Settings are now working. Only been a day but it's longer then before.
Hopefully this solved it.
There is another post about this issue also.
I have to agree, been working fine and the radio comes on when truck is started.
Thanks for the tip
Like anything else, when in doubt "reboot"
Thanks for the tip
Have you tried changing sources and checking? Even shutting down and then checking? Mine will do that. Once the source is changed sometimes it zeroes other times it’ll take till next startup to zero.
10 minutes ago, Drewt83 said:
where do u find the factory  reset option ?
Browse the radio menu's to Settings > System > Return to Factory Settings
2) Select Reset Vehicle Settings
3) Wait to reset
4) Select Erase Settings and Personal Data
You will need to reset your stations etc.
I did both options listed forreset
the radio has kept settings since doing this
Doing the reset has also worked for me so far. I did the user reset. Has been about 4 days so far and hasn’t reset. I’ve switched sources and everything has stayed put.
Aside from the equializer not holding my settings, the (2) auto volume won't stay set, the (3) maximum startup volume won't stay set, the (4) audible touch feedback won't stay set.  SO, i will try the factory reset and see if that works before i take it in next week........SURE MISS MY HD RADIO capability....
    Enduro73
    Enduro73
  • Who's Online   0 Members, 0 Anonymous, 1,262 Guests (See full list)
