The grill on the new Silverado Customs bug me, I don’t hate it but I feel like it could be better. I don’t see any aftermarket options other than colored letters, so I made a quick photoshop of what I think I would like it to look like. The photo I edited is not mine, grabbed it from another post.
The mod is subtle. What do you think, cleaner or weaker looking?
So why did you get the custom if you didn't like the grill?
1 hour ago, Silverado-V said:
Money.
I don’t hate it, just feel like it’s a little too plain.
I think they look clean.  Don't have one but like them.  I'm sure you can spice it up a little.  I don't even see what you did on the photo shop image.
The picture on the right has a mock up of a piece of trim below the “CHEVROLET”. It’s a minor difference but makes the space below it look a little closer to the same size as the space above it. I guess that’s why I like the LT grill better, because it’s centered.
He is what I did to mine. In the next couple of weeks I'm getting the bump painted same color as the truck.IMG_20201006_124039353_HDR.thumb.jpg.ebf7b1c677306ee357b9ae06812ee7c9.jpg
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,121 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
