I used it to do my 18" AT4 wheels. I like the way they turned out and think they are holding up well. It does seem to provide a better finish than the normal plasti-dip. It goes on thinner than the normal stuff so take your time and go slow. I layered it like I would spray paint and went a tad heavy on the final coat to get the wet look finish.
You can tell a difference up close but negligible from a normal viewing distance. Is it worth the difference? Maybe. Keep in mind, it cost almost twice as much...almost.
I'll post a pic when I get a chance.
Edited by Taco_Ninja
Spelling
Pics as promised. I think the 2nd and 3rd photo do it better justice but the pics don't show enough detail to be helpful. Kind of a satin finish up close.
This is the Shadow Black kit.
Resize photo
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
