So I waited too long to order from Speed Engineering, now they're not expecting any more stock until June. I've got a cat going out, and I'd much rather spend the money on headers than to replace it. Does anyone have any they're parting with? I've got a 2016 Sierra with the 6.2, so I'm looking for 1 7/8" with a catted y-pipe preferably.
Thanks!
Well I found some Kooks in stock ready to ship, so I ordered them. Helluva lot more than I'd hoped to spend, but oh well, I've always liked the way they looked. Mods can close this thread now.
3 hours ago, christophernelson72 said:
hey hi how are you got the  Headers and Catted Y-Pipe for sales at a very cheap rate send me a text at 2677049051
So you just joined and responding to a pile of WTB ads?
  • Haha 2
Yeah, there's been a lot of that lately it seems. Davenport⁶⁵ messaged me right away claiming to have a set of Kooks for $500, but then wouldn't answer basic questions without me clawing for it, and got bent over me asking for pictures of it with a sign with my name and date on it. The last message was 4/29.
Looking at the dates on the posts and the messages, they seem to be auto-sending when someone posts in this thread. Davenport messaged me again (twice) after your post calling out the other joker's post. We shall see if I get another message today after my reply to you.
  • Haha 1
Check OfferUp bro, I bought some speed engineering headers (thought they were tsp) but spent 300$ with a catless ypipe and also purchased a used Corsa Performance full catback exhaust (installing tomorrow)
Edited by Frankielozano214
Curious to hear if you get a message again as well.
Either way, good luck on parts hunt!
    rayredbone
    rayredbone
  • Who's Online   1 Member, 0 Anonymous, 499 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
