Hi All,
My first post, so I hope I'm posting in the right section. I checked a few other threads here on tranny slip issues, but none seem to line up with my issue.
I recently purchased a 2011 Sierra Denali 6 speed with 79k. When driving around normally (revs under 2,500-3k), the transmission seems to shift perfectly smooth up and down. But when I get on the gas heavy, I'm noticing some slip (engine revs to about 5k before the lower gear will engage). Eventually the gear does grab, but then it will peg off redline when it should upshift also. I checked the ATF and it was low, so I did a full flush and filter. The fluid still seemed fairly clean and unburnt. I am not getting any engine codes, my trans temp always seems normal, and there are no visible leaks anywhere (at least what my untrained eye could spot) at the lines up front or the pan. After the flush, it did seem to improve somewhat, but it still exhibits the same behavior when I really get on the gas. Has anyone else experienced this, and if so, what was your findings? Any feedback is appreciated, as I am trying to get to the bottom of this before my 60 day warranty expires.
Thanks in advance!
-Ben
I have a 2010 and my truck would do it while it was still under warranty, in both stock and tuned. Doesn’t throw a code, but mine slips under regular throttle and the RPMs will just jump. I change fluid every 40000kms and never any issue with findings. Also does it so intermittently that there is no rhyme or reason why.
Edited by mymaggiebell
Thanks for the input @mymaggiebell. I might try an additive next, as it is the only other "non-invasive" thing I can think to try at the moment. Its a shame to have these kind of issues right out of the gate, especially with only 80k on the clock. I'll report my findings if the additive works.
You could take it back to where you bought it and drive it with a mechanic in the truck. If they see what you are seeing then it should be something they need to fix.
  • 3 years later...
On 4/30/2021 at 11:45 AM, Ben W said:
Hi All,
Thanks in advance!
-Ben
My 2011 GMC SIERRA DENALI  has the 6.2 and my transmission got to the point it was doing the exact thing I took mine to BIG DAWGS TRANSMISSIONS and my clutches and some valve bodies were sticking. Fixed it in 1 day had it back 24 hours later $1100 it helps when you know the owner and you do a lot of welding and fabrication for them as well. There is also a valve body on that transmission you can tighten or loosen the control how smooth she shifts or how fast and hard you want it to shift as well, all depends on the way you turn it and how you like it. I do a lot of pulling so mine shifts fast and hard with a built transmission and new hardened gears I'm ready to pull the world on faster circles 💯😁
Just now, Dwayne78 said:
I would definitely take the pan off the transmission,  a lot of times these part time mechanics will leave the old "O RING" or seal in the transmission because sometimes they don't come out with the screen and stay in so when they put the new screen in it doesn't create a air tight seal so it sucks air and fluid does not get where it needs to go. I would check that first of all. And Lucas transmission stabilizer helped a few of my transmissions . Hope this helps.
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 281 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
