Is there a bull bar that can be installed on a 2018 gmc 1500 Denali without messing up the front sensors ?
  • 1 month later...
I remember seeing one out there, that has spots to relocate your sensors to.  If you do find one that does not interfere with the sensors, just remember that you can NOT park in the red zone on the sensors once it's installed.
