I scanned the QR code on my door sticker which does not appear to contain supplier RPO codes for the axles. It confirms GU5, Axle ratio 3.23 which I already knew, but I'm trying to identify who made the axles (GM or AAM) so I know what fluid to put in when I do post- break in maintenance on them. There are no SU_ codes listed which I read in other threads may identify the axle supplier.
Any ideas?
Thanks. I emailed them and they provided me the full list of RPO's/build sheet for my truck. SU4 and SU7, so, AAM axles on my '20.
There's different fluids for these trucks? Like as in my 2021 and somebody else same 2021 would use a different fluid in the rear and front axel?
GM released new gear oil specifications for the late 2020 and 2021 model year pickups that now call for DEXRON Low Viscosity 75W-85 gear oil (GM part #19365814) and GM Synthetic Gear Oil (part #19300457 meeting GM Spec. 9986375).
    Ryanwehr14
    Ryanwehr14
  • Who's Online   1 Member, 0 Anonymous, 321 Guests (See full list)
