I purchased a set of these to install/upgrade my factory non-bose speakers:
https://www.crutchfield.com/p_575T1675S/Rockford-Fosgate-Power-T1675-S.html?l=C
I am not sure how to wire up/install the cross-overs included with the kit to the factory amp. How would I do this? I am not interested in running new wires to the speakers. I want to use the factory wiring to power the new speakers.
Rockford fosgate manual: https://www.manualslib.com/manual/1339659/Rockford-Fosgate-T152-S.html?page=7#manual  I would be using the "standard mode" install.
Thanks!!
Edited by jashaw
I surmise you'll need an amp as just changing the speakers won't make that much of a difference.  Did you confirm the order? Says temporarily out of stock.
I was hoping to use the factory amp, but i'm assuming to get the best out of the new speakers, i'll need an amp like @mafd2 states.
Yes, I ordered the "open box" item a few days ago the price was $200 for a set. I ordered 2 sets of them to replace all 4 speakers.
How would I set them up using the factory speaker wiring, bypassing the factory amp, and using an aftermarket amp? With what I want to do, it looks like I need to use a loopback harness.
https://lljcustoms.com/t-harness-or-oem-loopback
Did you order the speaker harness?  The factory speakers have a plug that connects to the speaker.  You'll need a harness that plugs into the factory harness then to the speaker.  This keeps you from cutting the factory harness.  Not sure what colors the +/- wires are on the T1 trucks.
Yes, i did order the speaker harness. Plug-n-play to connect the 4 speakers. I have not connected the dash speakers yet.
I have the 4 speakers installed, dash tweeters, and two additional tweeters (came with the kit) installed in the rear.
I want to put an amp to them to fully utilize their potential.
The tweeters are 75w RMS, and the speakers are 100w RMS.
Will I need to use a 75w per channel RMS amp because of the tweeters?
How many channels would I need for the 4 speakers, and 4 tweeters?
The speakers, and tweeters are hooked up to crossovers included in the component system. https://www.crutchfield.com/p_575T1675S/Rockford-Fosgate-Power-T1675-S.html?l=C
I may add a sub in the future. I would need a spare channel for that.
    67elco
    67elco
  • Who's Online   4 Members, 0 Anonymous, 1,347 Guests (See full list)
