I just received an email from Onstar for advanced diagnostics. It said:
An issue with the Engine and Transmission System in your 2019 GMC Sierra has been detected. Please service your vehicle within 7 days.”
Has anyone else gotten this email before?  I didn’t notice anything while driving it today and it seems to be driving like it always has. Also, there were no messages in the DIC and no lights were lit up on the dash. Was just curious how serious I should take this email?  Thanks in advance for any help.
  • 6 months later...
23 hours ago, Bill Gorley said:
I just got it to on a 2021 GMC Sierra with less than 3,000 miles on it. What does it mean??
If you don't have a check engine light I wouldn't worry about it.
When OnStar detects an issue it will throw a code then OnStar e-mails you with the code so if you don't have a check engine light or code sent to your email I would worry about it or you can hit the blue OnStar button or your mirror and tell them to run a diagnostic check
Edited by Silverado4x4
I just had that issue yesterday in which I tried to start the truck and it immediately shuts down...repeated several times and got the same result.  Immediately afterwards I received an email from OnStar saying it detected an issue in the engine/transmission and need to get the truck serviced within a day.  As luck would have it, I noticed a check engine light on the dash.  I managed to get the truck started again and drove it home.  Earlier today I scanned the code and it stated a P12A6 that revolves around the fuel pump.  I've scheduled an appointment with the dealer to look at it and see what is req'd to resolve the issue.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
