Zaino Application
Kania2k1
How should this "system" be applied to the vehicle?  Circular pattern or side to side?  or does it even matter?  I think Z5 has to be applied side to side, but what about the others?  Also, should the application go as follows:
Wash/dry
Clay Bar
Z1
Z2
Z5
Z2??
Any help is appreciated
Hey Kania2k1 - When you're done with your truck can ya come over to Latham and do mine?  :withstupid:
I would like to know how you like the stuff once your done with the process.  I've been toying around with the idea of doing the Zaino treatment on mine.  Actually, I'm really interested in finding out how long it takes you to finish the entire process.
I preffer to put it on strait up and down(no swirling).
Wash good with dawn
Clay it
Wash with dawn again
dry!!!
Z1
Z5(as many times as you'd like)
Z2(always end with Z2)
I also do a coat of Z6 in between to help get everything off.
Cool, Thanks Mervz.  Lauriet, I've already got 2 coats of Zaino on it, but I'm driving down south and wanted an excuse to redo it :withstupid:   The first time I Zainoed it, it took about 4 hours or so.  Just to get all of the water from the low spots, like the mirrors and rear windows!
The vertical surfaces should be applied in vertical (straight up and down) lines.  Flat/Horizontal surfaces should be applied front to back, no swirls.
