My truck will quit pulling going down the road. I can stop put it in 4 high and back to 2 wheel drive and it will start working again. Has anyone had this problem? If so what fixed it? Thanks
What do you mean it stops pulling? Does it feel like it's in neutral or does it lose power?
It kindof sounds like your transfer case is slipping into neutral. Have you done any investigation while it's not working properly to check if it is the transfer case? Also, what does the 4WD button or lever do during this? Anything?
Without any more info, I would probably check the encoder motor on the TC. The encoder on the NV246 has been known to slip out of position
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   2 Members, 0 Anonymous, 584 Guests (See full list)
