Scott Vick Posted June 11, 2021 Posted June 11, 2021 My truck will quit pulling going down the road. I can stop put it in 4 high and back to 2 wheel drive and it will start working again. Has anyone had this problem? If so what fixed it? Thanks
Ian Mills Posted June 11, 2021 Posted June 11, 2021 What do you mean it stops pulling? Does it feel like it's in neutral or does it lose power?
Ian Mills Posted June 11, 2021 Posted June 11, 2021 It kindof sounds like your transfer case is slipping into neutral. Have you done any investigation while it's not working properly to check if it is the transfer case? Also, what does the 4WD button or lever do during this? Anything?
Ian Mills Posted June 11, 2021 Posted June 11, 2021 Without any more info, I would probably check the encoder motor on the TC. The encoder on the NV246 has been known to slip out of position
Scott Vick Posted June 12, 2021 Author Posted June 12, 2021 Also we ran a scan on it and no codes came up for transfer case
Register a new accountSign in
