Getting ready to order my new truck, either a 2021 AT4 or Denali, and was wondering if anyone has done anything with the mudflaps below the fender trim.  I'll be getting the colormatched fender arch moldings on it, and the black factory mudflaps look terrible afterwards!  Just curious of some options out there!
Thanks
I have the front and rear installed. The front of the rear tires wasn't released until this week and they are to ship out in early July from what the email stated.
I have oversized tires so the front caps still needed trimming but the rears were a clean install.
Edited by Dani2005
    Gkistler
    Gkistler
  • Who's Online   3 Members, 0 Anonymous, 881 Guests (See full list)
