Can anyone share a link for the OEM CV Axle boot kit for the 2018 Chevy Silverado 1500 (Front Right )
Are these pretty easy to install or does it Require special tools?
Replacing just the boot is a PITA.  It's much easier to just swap the half-shaft with a new/reman one.
To change the boot you have to disassemble that end of the axle once you have gotten it out of the truck.  That will probably at minimum require driving out a roll pin but maybe more and it will be a very greasy job.  If you swap the entire shaft, you save yourself half the work.  Just remove the axle like you would already have to do and replace it.
Either way, to get the axle out you'll need a big socket for the axle shaft nut a the hub, probably some stout pry bars to to get the shock/spring assemblies out, and a BFH or some other took to separate the ball joint.
You need a swage clamping tool to change it correctly.  The bigger end of the joints uses it to install the retainer ring.  The smaller end has a special pair of pliers.
84842044 for a new GM shaft $186.  I'd go with a new shaft for the price.
Edited by newdude
With the right tools, replacing boot/grease is cheaper otherwise its easier to replace the axle as suggested above. Plus some auto parts store has lifetime warranty on axles.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 449 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
