I hear that the 2022 or 2023 will have the larger infotainment screen.
right now, are there any after market products that can be purchased, that will be compatible with everyting in the 2021 truck, along with android auto...and maybe does split screen?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
