Hello everyone,
I installed a dashcam running the wiring through the passenger side a-pillar. Now my rear dome lights do not work but my front dome lights still do. Does anyone know if I somehow messed up the grey wire running up the a-pillar? I also disconnected the battery for 2-3 minutes and reconnected but it’s still not working. I’ll try the same tomorrow but does anyone have any suggestions?
    • It really is comical when people don’t agree or see the reason some people prefer the older vehicles. They become condescending. All the while they may be busting their knuckles on old vehicles. I have found memories of swapping out engines in my old GM cars in a weekend without much hassle. Unlike today. One wrong move a computer will shut you down. Even on something as easy as a brake job. There’s a pretty comical YouTuber called the car wizard. A garage owner who puts it all in perspective. Another Vicegrip garage that’s shows just how tough the old stuff is.
