Hi guys,
I'm trying to find a company who sells hidden winch mounting plates but got no succes. The only make I found is the rough country hidden winch mounting plate but to sent it to holland they ask $550. While the set cost $200.
Does anyone knows an other company who makes these plates? Or is it a better idea to make something myself?
  • 3 weeks later...
On 7/29/2021 at 12:57 PM, Larsson said:
Hi guys,
Are you looking for one that clips onto the rollers?  If so, there's one in this forum, somewhere.
I've seen several different ones on the internet.  Amazon has some for like $24.
Edited by Ravenkeeper
