What I'm trying to do: Create space for a couple of after market switched on my current switch panel.
What it currently looks like: blank-blank-start/stop, tailgate-hazard-tractionasst, supervised windows-blank-blank (pic attached)
What I'd like to do: Since the switches are in groups of three I'd like to take the middle set (tailgate-hazard-traction asst) and move it all the way to the right. Then purchase blank-start/stop - supervised window (part no 84482888). Then purchase blan-blank-blank (part no 84482869).
What it would get me: The left three positions would be blank with no wiring harness attached allowing me to install 2 after market switches into it.
Questions:
1) Will it work?
2) there are 3 wiring harness plugs, are they interchangeable with the switches? Will any switch work on any plug?
Wow!  So first and most importantly let’s clear up the any switch any plug. You would need to check to see what they look like on the back. Be sure to check pin configuration. My first answer would be don’t change the harness/plug arrangement. Try and move them together. Everything on that panel runs through the BCM Body Control Module and it loves to blow up with the slightest bit of resistance or shorting so I’d express caution.
so far as moving switches 2 switches = 2.25 inches and one dummy = 2.25 inches so I’d deduce that movement is possible. I would not under any circumstances cross the harness to a different switch. What may look identical may trigger a completely different signal. Even though most are single function you have some like adjustable accelerator pedal that requires a long hold. The 12v activator is a long hold where hazards are just a single tap on off signal so you just don’t know. I believe you should be able to pull the harness over 2.25 inches.
hope that gives you some insight
USMC
Thanks!   Well it sounds like its just not going to work.  Since the switches are grouped by three I can't just move anything over without trying to combine switches. Based on your advice of not switching plugs I'm outta luck. The plug on the left controls 1 switch with 2 blanks, the plug in the middle controls 3 switches, and the plug on the right controls 1 switch with 2 blanks. If I couldn't combine the two single switches then I'm outta luck.  Guess I'll have to lean towards the GM Outfitter option.
Thanks!
Semper Fi!
Have you pulled the pane to see if there is a way to separate the switches?
I don’t want to be overly cautious, but when it comes to the BCM. I take no chances. I’ve replaced more than one during my folding mirror drama.
So let’s move group 1
110 v
skid
Flashers to the left
then
tail  gate
Auto stop
hill descent moves left
now you have a a spot for a 3 bank
at that point you can buy any s bank and all you need to do is run your own wires to them.  What is it your trying to control with the new space ?
Well actually you would need a 3 bank fill plate or a 2 and 1 because the  gm switches are all dumb. They just tell the BCM to do something. So you would need some type of custom switch that could mount through the fill plates
My grouping looks like this (attached). So if we go left to right
Group one
     Blank
     Blank
     Start/Stop
Group two
     Tailgate
      Hazard
      Traction Control
Group three
     Windows
      Blank
      Blank
Because they are in blocks of three and I can't separate them I can't move them.
I think this might look a little more o e m then the green one. I’m still searching for something to maybe go where your blanks are.  What exactly do you want to control?
Yup, I've seen these and a few install videos.  I'm looking to control a few lights and a power horn.  I think the cost of the upfitter package (switches, trim, panel, harness) is going to make me lean towards the aftermarket controller. It will just depend on how I feel about the proclipsusa mount locations. I don't want to drill holes in the panels just to set a mount.
Btw. Have you been under your dash yet? Gm gives you exactly 1 accessory switched wire that I can find. Slim pickings under the drivers side. Passengers side seems to have more of the optional sources but still much tighter over there due to the ac box.
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
