"Flow Bench Fallacies"
Port velocity is the most important part of head flow.
You can put small port heads on a 454 Chevy with a
750 Carb. and produce more touque at lower rpm
than you ever could with large port heads and a 1050.
We spent a lot of money on expensive parts back in
the 70's that actually ran slower on the quarter than
our old passenger oval ports with a stock tock Holley 750.
You can go to Reher & Morrison's web site and read
several of David Reher's articles. He is one of the smartest
people I have ever seen when it comes to the Chevy
racing engine. :thumbs:
