I have a 2000 silverado that needs a rear end, would it be best to just put in the stock 1500 rear end with the 3.74 gear ratio that my truck came with or would putting a 2500 rear end with the same ratio be a better bet?
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
