easy fix but more $$$$ is to buy a set of eibach lift springs they will give you another inch.....i run them on my elevation
i am sitting @ 3 inches in front and 2 in the back....with stock front springs i would be 2" in front
Edited by Dunn
17 minutes ago, Trevor Towers said:
Okay, yeah that looks pretty bad - I see what you mean. You need to ask the installer what location they put the circlips in on your shocks.
Nevermind, I think you are stock up front. I’m losing it, I’ve been inside the last year and a half!
I just noticed your UCA's are aftermarket.  DId they go on at the same time as the rest of the lift and if so, did you check to see that they were correctly clocked?
