The refrigerant capacity and type is listed in your owners manual, on Google, and listed on your truck's radiator cover.  Looks something like the attached image.
  • 99silveradoz71 changed the title to 2016 Silverado Freon capacity
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 716 Guests (See full list)
