I've got a 2020 Silverado RST 5.3.  About a week ago I got a a Service ESC - Brake System message on my dash along with one of two limp modes, either speed limited to 62 miles per hour or 43 mph. The issue is intermittent but when it does happen the abs system shuts down and the brakes feel like they are full manual brakes.
I have an appointment scheduled for the dealer on Tuesday but I was able to run the codes via my main mechanic.  It shows a U2413 code which is a Serial Data Gateway Module failure.
It throws a bunch of other codes related to not being able to communicate to other modules.
Hoping its just an ESC flash similar to the 2019 recall but who knows. Considering pulling the S&B cold air intake to avoid any warranty issues.  Thoughts on this?
Mods on the truck
S&B cold air intake
Amp-research steps
Hypertech Speedometer Calibrator
Autostop Eliminator
Question of they day: "Have you ever worked in the car industry?"
I went to pickup the the truck after a reprogram of the brake control module and a 5 mile verification drive and that was the question asked when they pulled the truck up for me.
Perplexed I said no and he said,  "Are these the same esc warnings you were getting when you dropped it off?" Yes sir same exact messages.
So needless to say I got a lyft to work and they took the truck back to run the codes again and take another look.
Got an update today. They are replacing the brake module.  The part is coming out of California to Arizona so I should get the truck back early next week.
They replaced the master cylinder and brake module.  Worked great for the 1st day.  The next morning I had a Service Brake Assist message on the screen.  Back to the dealership.
On 9/16/2022 at 9:53 AM, idle_liquid said:
Did you ever get this issue diagnosed correctly? I am getting the same codes on a 2019 Silverado.
This is certainly not what we like to hear, idle_liquid.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2019 Silverado. To do so, please send an email to [email protected] with ATTN: idle_liquid/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 3 years later...
Well did you ever get it straightened out? Mine threw that code and all the lights and gauges went black as soon as i pulled onto the highway. 2020 GMC ZRX
...just fyi, you probably won't get a response from idle_liquid, as that user signed up, made two posts on one day, more than 3 years ago, and never returned to the site...
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 681 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
