Let's talk Boats here
General Lee 01
The more times I visit Bass Pro Shops the more I want a friggin' boat! :cheers:
So I'm going to put "Boat" on my list of "things I plan on having within 5 years".
I kinda want one of those Boats that look like they are suited for Sea-fishing. But I have sme Questions.
Are Bass Boats Ocean worthy?
What Kind of boat is recomended for just plain cruizing.
I'm not big on fishing, but I like the sleek-ness of Bass Boats. Can you do other things with Bass Boats?
  • 4 weeks later...
Bass boats aren't good for much of anything except going bass fishing. They have little freeboard so are easily swamped, and have wide flat bottoms so they don't ride well in chop.
Taking one offshore would be tantamount to suicide.
Bass boats are the last thing you want out on the ocean, even in calm seas. That style of boat is designed for minimal chop, maximum speed and shallow areas. They'd be just as bad as a ski boat.
If you're headed out to sea, you'll need something with high sidewalls, a good bow to push the water away from the boat and a deep-V hull configuration to smooth out and control the ride. Look at Grady-Whites or Boston Whalers for some nice rigs.
In the boating world, you do get what you pay for. But no matter what boat you get, remember BOAT stands for Break Out Another Thousand....
  • 4 weeks later...
ToeJam is right about the "Break Out Another Thousand" rule...Not to mention that anything that is worth it's salt offshore, is going to cost you a pretty penny in the first place.
Some bassboats are cool, like the Allison...Those suckers go over 80! :thumbs: But they are squirly when they do it, and won't go very fast in any kind of chop.
You need one of these....If you had been around a couple of months ago, you could have bought this one.:devil:
Bass boats are only good for bass fishing on lakes with little chop. They are quite fast but only when the lake is smooth. You want a V hull boat. Looking cool is not fun when your boat is all over the place on a choppy lake.
That Baja is badass...Lake Travis is AWESOME! I live in Katy, TX and typically drive to Lake Somerville, but my grandmother lives in Spicewood Beach on Lake Travis and I love going up there (3.5 hr drive) We take the ski boat (Sea Ray) and the two jet skiis (Sea Doo GTI) up there - that is a gorgeous lake.
Jeremy, If you are not into fishing check PWCs. I just picked up my new Yamaha HO FX Cruiser. It is a great boat that is alot of fun to ride (tops out @ 60 mph) but great for cruzin. I can't wait for better weather so I can ride it.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
    • It is 4wd. shop told me it is the slip yoke. But not sure.
    • No, I did not tune out vvt. From what I read it should still be able to run without it, it'll just lose some torque/power.    I can see how that would make it not run correctly, but why would that cause the faulty MAF readings?   EDIT: I just ran a quick test and checked, and as I expected, the computer sees that the VVT cam phaser solenoid is not present, and throws a code for it, and does not try to change the cam angle at all. Commanded position just remains at zero, 100% of the time. This makes me think that the VVT is most likely not the cause of the problem though if anyone has a different/better explanation, I'm all ears.   UPDATE: I was able to find that my scan tool does indeed support reading the frequency (hz) off of the MAF (I thought it wasn't supported but turns out I just didn't know where to look for it). I noticed that regardless of engine state it always however this Is not what I observed with my multimeter. Like I said before, the MAF seems to put out a normal signal during cranking and then the signal drops to a very erratic reading once the engine is running. It seems from what my scan tool is telling me that the ECM is not recognizing this at all, and just reads 0 Hz 100% of the time. This pushes me towards the the PCM itself is faulty. I I have the PCM out of the 2007 donor vehicle, which I may try to connect and program (it's only ~50 bucks to get the software for a one-time programming)
    • Did you tune out the VVT?  07-09 they did not have VVT.  2010-2013 they did.      If you haven't tuned it, its trying to adjust cam timing.
