About a year ago we were on a trip and the truck would not start.  Finally got it to Jump.  Got home and went to Auto Zone.  Battery tested marginal.  Bought a new battery.  A few weeks later it was the same thing.  Repair shop said starter had a bad spot.  New starter.  Doing the exact same thing again!  Had the truck towed to the shop.  They do not work on weekends.  Maybe I will hear something tomorrow?
Insert key and turn switch on.  All lights, radio, phone, jukebox all work.  Turn key to start and everything goes black.  I am thinking a few rounds from the 45-70 and go buy a FORD!  Any thoughts?
2 hours ago, Snowcamo said:
Grounds.check them.
OK...But remember it did this same thing a year ago....
I have a 2014 Sierra, never a problem till transmission went a month ago at 144411 miles. Shop had for three weeks got back the evening of 9-1-21,drove to work the next day no problem, went to leave work at 5 that afternoon does the same as yours. Turn the key and everything works try to start and dash goes black and click. Starts when it wants too. Had battery checked, was  good, had starter checked it is good, spent Saturday changing cables and pulling all grounds I could find and cleaning them,put all back and started like a champ till today, no start no crank again, hope your shop can figure out
    Sothpaw27
    Sothpaw27
  • Who's Online   6 Members, 0 Anonymous, 603 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
