On 11/6/2021 at 1:26 PM, Keegan Hurst said:
Hi, so I have a Sierra at4 with the LED emblem in the front. Is there a way to just pull out the emblems to paint without removing or unplugging the whole thing?
no have to remove grill and take out from back
You can pull the OEM emblem off without removing the grille.  I did it to put the black bowtie on.  The GMC is held on like the Chevy with clips from the front.  If you have an interior removal set get under it from the bottom with a clean cloth between you plastic tool and the grille so you do not scratch it.  As you slide the tool to release the clip from the grille gently pull out and it comes off in like 10 seconds.  With your LED install you will have to fish the wires thru to tie into a running lamp power.  You can remove the grille, it is not hard but for me the entire switch took less than a minute.  Now you have to add time to run you wires.  Here is a youtube clip of a guy pulling his from the front on a 2021 GMC  Truck Badge Removal: 2021 GMC Truck logo swap from front grill - YouTube
    • 2024 l8t . Ac has never felt really cold even new. But lately it seems a little warmer. When it gets in the upper 80s and a little more humid it just does not keep up. And sometimes at idle it gets warm. My wife's 2008 envoy is better. My son's 2016 is colder. I have an apointment for a third try Monday the 29th at a third dealer to try and get cold ac before my warranty is out. The first two told me something about so many degrees under ambient temp blah blah blah seemed like they didn't want to mess with me. This was set at low. Max air fan speed high. 87 degrees and a little humid.   .
    • It isn’t all that bad in the world with purchasing power versus quality. My first car had just basic equipment. My oil choice was conventional oil. The life expectancy was around 100K miles. During that time you could expect to change all the accessories. Today with inflation you can buy the equivalent. It comes fully loaded with 4 doors. The life expectancy passes 100K miles replacing no accessories. If reaching that milestone is your goal you simply follow the recommended service intervals. If you want more miles simply do more maintenance. When in doubt you can check the internet or YouTube for information. The selling of any product hasn’t changed since the beginning of time. The power of the buyer has. The price of the product hasn’t changed much with inflation. The buying public wants more. Competition and the buying public has put the sellers in a box. The greed is on both sides. You can still get more for less. You just have to do with less. That used to be popular. The buying public has changed . It’s the sellers that are trying to keep up. As Grumpy tries to inform the readers in this case with maintenance. If you want more. More effort is required. That information wasn’t available this easily just a few years ago. I believe the public has more power. Getting information is easier.
    • Gentlemen, I'm new to this forum. My question is, I thought I have read somewhere that the rear wheel liners for 2024- 2026 GMC Sierra HD3500 DRW can/will fit the 2023. I can't seem to find that information again and wondering if anybody has any knowledge if these will work or not with the 2023? Part# is 84892542. Thank you for any information. The GMC parts counter wasn't able to give my any definitive answer?
    • Spacers aren’t safe anyway, so you’re better off just buying something else.
    • Its because they have thread locking compound on them. I would bet money that they are actually reusable and not a literal TTY bolt because GM and most other OEMs don't trust techs and the end-user to apply thread locker properly in the same way they don't trust anyone to solder properly (and instead instructing crimps everywhere). Torque To Angle =/ Torque To Yield.   If you think dealerships or any technician replaces every 'discard' bolt in every procedure, I have a bridge to sell you.
