So, driving to the home depot this morning I didn't get too far, when accelerating the engine died and a check engine light appeared. I was able to restart and limp it closer to home, before finally towing it with the front tow hooks and a strap with my dad's truck.
So google says this generic OBDII code is something like: P0232 is triggered when voltage in the fuel pump secondary circuit is shorted to vehicle power through the relay
Which searching around on here seems to be related to the fuel pump, which makes sense. I recently put some old gas from my motorcycle and an old gas can into the truck to burn it, this was a tank and a half ago though, so I would have assumed it was all used up. (maybe 5 gallons total of old fuel) I think the gas may have had some stabilizers or cleaners in it, so maybe those loosened some trash up in the tank. But who knows maybe the pump just gave out, but I figured a clogged fuel pump would quickly draw a lot of power causing the ECM to kill it to prevent it from burning itself up.
Looking around online, it seems people either drop the tank, or loosen the bed bolts and lift the bed to access the fuel module at the top of the fuel tank.
I figure I'll just use AAA to tow it to the dealership and have them fix it, as dropping a tank is always a pain in the behind. I suppose I could try to figure out if this is an electrical problem instead, but I highly suspect a clogged fuel tank.
Let me know if I'm on the right track or not, maybe it's not the fuel pump at all
Can you give some current info?
What year?
Mileage?
Engine?
Previous maintenance recently?
Oh yeah, 2014 Silverado 5.7L 127,000 miles, so it's probably due to go out just from age. Maybe the fall season cold morning temperature cycles contributed some. Maybe my old gas was fine, but timing seems suspect, it looked a little green but I dont think it had anything floating in it.
Never had any issues with the fuel system before now, I usually run Ethanol, but have maybe 75% gas to ethanol currently, only thing I've really done on the truck was the A/C condenser in terms of service
And I’ll chalk this one up to the “I should always do things myself”  column, picked up from the dealer $1423.15 for new fuel pump installed
Breakdown was something like this give or take (not exact from memory left the paperwork in my truck)
$169 diagnostic
$69 15% shop service fee
$400 for part
$900 for labor
I was expecting $900 total (which even I thought was high) but cost way too much. But it was very convenient as I didn’t have to do anything.
Supposedly should be 4 hours of labor, so labor rates must be outrageous
Edited by awright2009
$169 diagnostic
$400 for part
$900 for labor
That price is painful.
    doylej24
    doylej24
  • Who's Online   3 Members, 0 Anonymous, 755 Guests (See full list)
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
    • Its just that it worked on 2024 trucks on this forum and my 2025 model truck, unless GM did something since that point to screw up access or Autel has a bad update. I haven't had need to use my tool since last year when I did the changes to the placard pressure settings and since then I updated the software on my Autel but have not plugged into the OBD so hard to say if I would get a surprise as well.    All I know last year when I bought the Autel I was warned to be sure to update it before I tried using the unit as they said who knows how long ago unit itself was actually manufactured as the software could be way out of date.
    • And so you had gone through the process of registering and updating the tool and so on ?. All I can say is that on the front page as the tool fires up you go to advanced mode, then vehicle model comes up and you choose Silverado ( not the DRW or EV  since your a single rear wheel ) , then I think its choice 2 which is 07/2021 - 12/2026 ( 433mhz 13542523 ) as that is the series of tpms sensors and then go down to choice 5 which is tire type/pressure selection. Hit yes and it says to connect to OBD port and turn ignition on.    Having said this, I updated the software in my tool lately and these year range choices look different from the past due to them doing some updates it would appear and I have not connected up to the OBD port since last year so hopefully I am not in for a surprise with them screwing up the software and that it won't work on my truck anymore either.    So my question is, when you plugged into the OBD and started your truck it had that message on the Autel screen "vehicle not supported" ?. That does seem odd as tire shops would be pissed right off if hey can't use their tool on the model year after mine that in theory is supposed to be much the same truck ... unless GM did some change in the computer system to block certain things from access.
    • Understanding and using modern scan tools is its own body of knowledge. I had little hope that would work...programming access to the BCM is probably required and that is not easy for us consumers. Expensive scan tool, GM programming subscription, online authentication, etc.   It also may be a matter of finding the right dealer to program it for you. Flashing a modern BCM might be a little too advanced for most tire shops.
