12335659 Front bumper fascia (unpainted)
12335660 Rear bumper fascia (unpainted)
12335692 Rear bumper fascia upper step pad
15197888 Rear bumper impact bar
12335767 Front left brake caliper duct
12335766 Front right brake caliper duct
I think there are some brackets for the front bumper too. I don't have the part numbers for those. Also, the rear bumper will stick out past the rear fenders unless you install the side cladding too. I have the part numbers for the cladding too if you want. Thi stuff is $$$.
I'm thinking of buying a SS bumper cover now b/c my chrome bumper has a dent in the middle of it, what all would I need to buy and also would I need a new front bumper all together in order for this to work
thanks
thanks
If your bumper is just dented a little you should be okay. I've heard that there are some aditional brakets that need to be added to use a GM SS cover. I don't know those part numbers. Street Scene sells a SS look alike cover that is much more affordable than the GM stuff.
The Street Scene cover fits great and looks great, it will save you $$$ We just put one on my kids Chev .........looks almost as good as my GM...LOL
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 193 Guests (See full list)
