ok, i got a 2005 regular cab Gmc Sierra with the 4.8L V8 and the NV3500 manual 5 speed transmission, I have a few moods install maybe 3 or 4 month ago like stage 3 cam long tube headders, street tune with hp tuners, i got this truck as a second owner in 2007 with 50,000 miles and never change the clutch, she has now 173,000 and yesterday my clutch went out, gone. Can someone point me in the right dirrecction of a good, affordable clutch i was thinking stage 1 or 2 the most there so many out there but not good reviews... Thank you!!!
South Bend is pretty big in the diesel world:
2005 CHEVROLET SILVERADO 1500 South Bend Clutch K04232-HD-O South Bend Clutch Stage 2 Daily Driver Clutch Kits | Summit Racing
"South Bend Clutch Stage 2 Daily Driver clutch kits are engineered for vehicles with HP modifications.  South Bend Clutch Stage 2 Daily Driver clutch kits are recommended for daily performance, street, and moderate race vehicles. "
Diesels = high torque so good clutches, especially modified are necessary.
Edited by newdude
I bet you can get a pretty good heavy duty clutch at NAPA, Eaton makes good clutches. Used to be a clutch called "Rev-Loc"; I think they became "Center Force". They put little weights on the fingers of the clutch (where the throw out bearing contacts the pressure plate) the theory being the centripetal force was increased with the weights to make the clutch engage with greater force that could be produced a diaphragm type clutch spring (works like  the bottom of an old style oil can); I say this only because I have seen this type of clutch with the weights used on a GM product. Chrysler used to use coil springs, I think Ford used to use diaphragm style springs but am unsure what's going on nowadays.
When I was in the service in Vehicle Maintenance the M-35 trucks (6 X 6) used a a clutch plate that wasn't like a disk but more like petals of a flower, I see that's still considered the last word in heavy dutiness.
  • 3 weeks later...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
