I know it's a long shot... For such a well done and well built truck it surprises me how many little things seem to have made it past the engineers' desks that I would categorize as utter stupidity. The operation of the fog lights with autolights being another!
Anyway, since the time change I've noticed on a number of occasions, especially while cloudy, that the interior lights in my truck are uncomfortably bright. The truck seems to detect daytime vs not daytime and change some behaviors accordingly, such as enabling the interior lights dimmer. when the truck thinks its daytime the interior lights are on full brightness all the time and the dimmer has no effect. In many situations I find that I really want to turn the dimmer down a couple of notches as evening is on the way but before it is dark enough for the truck to think its nighttime. This is especially true if whatever is on the nav screen happens to have a bright background. But of course, in daytime mode the dimmer buttons do nothing.
Does anyone else notice this? is there any solution? I wonder if it uses the cameras to detect daytime or if this truck still uses a stand-alone light sensor. I'd be tempted to try to bypass it and tell the truck its night time all the time (put a piece of vinyl over it maybe!) so that the dimmer would work at all times. Any side effects of doing this? Sunload sensing for climate control? I'm not sure what else such a sensor would affect.
Now you've got me curious and I'll have to pay closer attention to my truck.
I would *think* the easy fix would be to manually turn on the headlamps (turn switch from 'Auto' to the headlamp setting) so the dimmer switch becomes enabled.
Edited by NorthskyblueT1
Unless I'm doing something wrong mine goes based on the sensor only. Even if I have the headlights on manually the dimmer is still disabled unless the truck thinks its dark enough to be in "nighttime" mode. I find often enough, especially while cloudy, that its dark enough that I wouldn't feel comfortable without having lights on. Maybe not headlights but parking lights + fogs often and the truck might still think its daytime. its that scenario where the interior lights are uncomfortably bright but the dimmer still is disabled and the lights are on their full bright mode at all times.
I guess my 2019 Sierra is old school. Has the sensor on the dash, which I believe most vehicles have as standard. But the auto dim? I haven't noticed it. I'll have to check it. Have you checked light settings on the DIC?
I should review what's available in there. I haven't gone through the settings in a while.
I did notice one thing though, the dimmer isn't completely disabled even in day time. I notice mostly because I have aftermarket gauges which get their backlight from the backlight circuit on the row of switches below the climate control. the dimmer seems to work for that backlight and my gauges as a result, but in daytime mode the instrument cluster and nav screen are on full brightness all the time. I can still dim the rest of the interior lights, just not those. Unfortunately those are the ones that are causing the problem.
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,441 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
