5 minutes ago, CFRED70 said:
How many miles would you say are on the General's?  I'm in Central Ohio...might be interested.
28,000 miles - I have had them on my truck since new.
    smandy
    smandy
  • Who's Online   1 Member, 0 Anonymous, 465 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
