Anyone had any issues running this kit with factory aluminum control arms? Haven’t purchased yet but will most likely set it around 2.5” front 1” in back.
My understanding is that if you go with a full level (2" - 2.5") You're opening yourself up to potential failure if you don't upgrade the control arms.
Edited by M1ck3y
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 353 Guests (See full list)
