 Have a2019 crew with the 6 speaker Bose system .I am dissatisfied with the performance the bass distorts pretty bad and vibrates the front door panels horribly. I am looking into adding a sub in the back what do I do with the front door speakers? Bass block ?turn them into a mid bass ? Unplug ?  Dose the Bose amp only send low frequencies to the front doors? Does anyone know the frequency these are playing ? Would like to put in some 2 ohm coaxial however I fear they are only sending lows to the doors
I think you have something wrong with yours. The bose system in our trucks sounds fantastic at max volume. I dont hear any distortion. Maybe the door panel is missing a clip or 2?
maybe try moving the balance all the way to one side so you can test to see if it’s both or one of the door speakers.
sorry to say this and I may start a whole new debate, but stock systems are inferior....especially Blose.
    MASONV88888888
    MASONV88888888
  • Who's Online   3 Members, 0 Anonymous, 1,563 Guests (See full list)
    • I have 2 choices.
