2015 Chevy Silverado 1500, High Country 6.2
Last time my friend used a tractor to load something onto my truck bed and the bucket got caught on my tail gate cable and broke it which caused the tailgate to hung on just one side cable and the rear camra wire. It must have pulled the camra wire loose or disconnect from the housing inside the truck bed? How do I go about fixing this issue. When put on reverse, the screen says "rear camra service" Thanks in advance!
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
