I replaced my tail lights with smoked lense LED lights.  They came with built in resistors but still go into hyper flash now and then.  They actually hyper flash more than they normal flash and it's random.  I figure it must be the built in resistors failing, but I don't know for sure.
I've search online to find remedies like replacing the relay fuse with an LED rated relay, but I can not find an actual relay for my truck model.
Has anyone else delt with this issue or know what I can do to stop it from hyper flashing?
Is your headlights LED? I came across this problem when I installed LED tail lights. I had to add this: HUIQIAODS H11 H8 H9 880 881 Wire Harness Kit 50W 6Ohm LED Load Resistor Fix Hyper Flashing Blinking Canbus Error Warning Canceller Fit Upgrading LED Headlight Fog DRL Light 2PCS
In order to stop the hyper flashing.
