So the issue I'm having with my 89 k1500 5.7 the heat will only blow luke warm out of the vents and defrost it seems to blower warmer out of the floor vent I've replaced the heater core and checked the hot/cold flap and is seems to be working as it should and the t stat is not stuck open temp gauge is reading around 180 when driving it's 5 degrees out side I tried to block off the rad to get temp higher and is seems to make the heat cooler any help would be great 👍
Can you put a temp gun on the heater core lines itself to see how hot those are getting?
if not feel the heater hoses, they should be about the same temp. if 1 is cooler than the other you have a restriction somewhere. they should be almost too hot to hang on to with a high idle fully warmed up. if that checks out it has to be in the heater box. did you do the core yourself ? AC? manual or electric controls?
so it has a restriction either in the heater core the hoses or the pipes off the engine. if the feed pipe comes off the manifold pull the hose and look for corrosion or any trash that may be there. if thats clear pull the return and hook up the garden hose to back flush the core. they make a tool that attaches to the g hose with an air fitting on it to give it a good blast but a regular hose with good pressure will do the trick. watch what comes out when you hit it with the water you may see a blob of sealer or other smat come out
if you get a bunch of crap out of the core you may want to forward flush it then reverse it again to get it all out then figure out why a new core clogged. I know in the late 80s they had a problem from not cleaning out the casting slag when they cast the blocks but that usually rotted the freeze plugs from the inside out
if it still has those quick connect fittings on the engine that may be your clog . you can get new 1s or replace them with a nipple, they usually leak if you try to reuse them. careful they often snap off when you remove them. if they do the best way to get the broken piece out is to cut it almost thru with a saw blade them carefully collapse it with a chisel then chase the threads
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 410 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
