Does anyone know any reputable custom tuners in the OKC area for this motor.  Also would be interested in hearing what other mods I should make prior to tuning.  The only done to it is aftermarket exhaust.
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 719 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
