I took my 2022 gmc 2500 duramax truck in for an oil change and they said it had a recall. They were not very forth coming with info but said it had a issue with programming and codes not showing up and they had to remove and iinspect cam sensor. Anyone heard anything about this?
Edited by txab
There's bulletin N212351210 for 2022 L5P:
"In certain 2022 model year Chevrolet Silverado and GMC Sierra vehicles, equipped with a diesel engine, the Engine Control Module (ECM) may not properly detect faults, set DTCs or illuminate the Malfunction Indicator Light (Check Engine Light) if these fault conditions occur:
  • Charge Air Cooler (CAC) low efficiency (DTC P026A)
  • Exhaust Gas Recirculation (EGR) cooler low efficiency (DTC P2457)
  • NOx sensor position 1 slow response (DTC P22F9)"
Reprogramming ECM is fix for this.
Not related to any cam sensor fault though.
