I have a 2018 I am looking to do a Barricade Bull Bar on. However, I do not want to run the wires and add the relay. Is it possible to tap into the fog lights and run this with them? Has anyone done this yet or is there another forum on this topic?
https://www.americantrucks.com/barricade-hd-bull-bar-w-skid-plate-20-led-dual-row-led-light-bar-textured-black-07117-sil.html
Why not talk to the seller and or the manufacturer of this bar and find out how to hook it up where you want to?
I personally would not connect to the factory fog lamps because they are engineered to provide a wide beam closer to the truck where you need it.
Versus the LED bar on the bull bar that provides a wide (mostly straight) at a longer distance.
I would not run both as I think they would be unsafe and the bull bar LED bar would blind other drivers.
You can wire it to a switch inside the passenger compartment, then you can turn it on as needed.
