2017 Colorado Duramax 44k miles
hello everyone,
I'm at a loss for ideas and apparently so is my dealership, so im asking if anyone has had this issue before.
one day I started my truck up and I heard a weird metallic THUMP for a split second. I turned the truck off and restarted and it didn't do it again. when coming to a stop light i heard the metal THUMP again coming to a stop and then again when i took off. also while driving home and coasting into a turn (no gas  just brake) I heard the noise again. before I hear the noise I can feel when it's going to happen. it's hard to describe but it's as if you can feel a weird sort of....tension?...in the pedals and steering wheel. I took it to the dealership and the "gm techs" told the maintenance department that it was the values in the transfer case and to switch those out. I picked the truck up, took it home....no issues. next day I start the truck up again I hear and feel (very prominently) the noise again.... almost like two hollow, metal tubes hitting eachother. however, now it's very prominent when I'm driving. the noise feels as if my front end is fighting itself to sync together. when this happens, coming to a dead stop and a few seconds after....the front end vibrates/rumbles and you can feel it on the pedals and steering wheel. the rumble/vibration is loud in the cab so I can imagine it is equally or more audible on the outside.
I made another appointment for them to take a look but this is very frustrating because it's been a month long process for them to ultimately not fix my issue and make it worse.
I'm going to try attaching a video to this questions and listen closely on the startup. that's the noise it makes but it's louder and more rough now (with the added symptoms)
truck noise
Edited by ubernin
    ChristopherDobson
    ChristopherDobson
  • Who's Online   5 Members, 0 Anonymous, 1,296 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
