Besides the obvious, are there other mechanical differences?
  • Do the 17" vs 20" wheels create a different ratio?
  • Does the DRW have bigger brakes?
  • Anything different with the axle?
  • What else?!
  • What else?!
1.  3500 srw and drw run the same rear axle ratio.  The smaller OD tires on drw help with giving it a higher overall gear ratio.
2.  I believe the front brakes are same but rear are larger on drw.
3.  Gear set I believe are the same but axle shafts are stronger on drw.
4.  Biggest difference is the rear spring pack.  The drw has alot more force in the underloads.
#iworkforGM
    timcpeters
    timcpeters
  • Who's Online   2 Members, 0 Anonymous, 1,199 Guests (See full list)
