I have a 99 classic tahoe 4x4. It's been wrecked and every body shop I've talked to about fixed the bent frame is saying it can't be done I need to swap it. My question is can I swap my 99 frame for a 2000 yukon frame since that's the only one I've found? Or can I use a rwd frame and change everything over to it off my 4x4 to make it a 4x4 I'm not finding a clear answer on either one.
A 1999 classic Tahoe would use a GMT-400 frame and a 2000 Yukon would be a GMT-800 frame.
I have a 99 Silverado regular cab 2wd and I’m wanting to make it 4x4. Can I use a 2003 Tahoe 4x4 chassis with all 4x4 components and put my cab and bed on the Tahoe frame?
    Bert 22
    Bert 22
  • Who's Online   2 Members, 0 Anonymous, 647 Guests (See full list)
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • I can't believe that could possibly be the case. It should be 36mo/100k miles from installation. Then again, it also seems like since a dealership installed it, it'd all be in the system and you wouldn't need to worry about registering, either. Shows you what I know. 😄 Hope this one outlives the warranty!
