I have a 2021 HD Custom.  I would love to install a roof rack but am pulling my hair out trying to find something online that I know will work.  The only thing I'm finding requires drilling.  Has anyone here installed a roof rack?  Help!
What are your plans for installing a roof rack/ why do you need to install a rack?
I know for the 1500s there are roof racks and i am not sure if they would fit.
I am installing a bed rack (and will put a roof top tent on it) for overland camping and would like a roof rack to either hold another rooftop tent (family of 6) or to hold other items.
