I'm thinking about doing a dod delete on my 18 Silverado. Somebody told me if I have this done there's a chance I may get a check engine light thus making it difficult to pass NJ inspection. Can this happen?
Edited by Willard Burnight
Are you talking about physically removing all the parts or just wanting to install a AFM/DoD device that turns it off.
One is many thousands of dollars to do and the other only costs like $150. If you removed all the parts, it would have to be re-tuned by a shop and they would have to turn off all the error codes that come with that. The cheaper plug in device should never cause a check engine light.
Yep, as Cam said, full mechanical DOD delete you need it tuned.
If you are talking leaving the mechanicals alone and just turning off DOD, a shop can do it tune style where they go in and just turn off DOD, or you can use an OBD device like a Range.  The only problem with the Range is, if NJ does an OBD emissions inspection, you will need to drive around for a week with the Range removed so the truck can run the readiness monitors, otherwise you won't pass.  The tune the ECM method would make it so that didn't happen.
A tune would make all the check engine lights go off.
You can't even start the truck after the DOD delete without a tune.
    blueskytruc
    blueskytruc
  • Who's Online   3 Members, 0 Anonymous, 618 Guests (See full list)
