Hey! I have bought GoRecon headlights for my 2022 Silverado Custom. (Non refreshed version So still looks like 2021). I was wondering how can I take off the front grill and stuff to put the headlights!
Also. I’m planning to install a 2 inch leveling kit from rough country. Would 295/55/20 Fit perfectly? Or can i go up to 305/55/20. Thank you!
TONS of youtube videos, here are two:
For tire fitment, the search function is your friend.
Why are you removing the bumper? You only need to remove the grill and side panels of the fender to change the headlights. I did mine about a month ago. The video I found said there were 5 bolts on each headlight when there are 6 and you HAVE to remove the side panel that wraps around the headlight because it snaps INTO the headlight itself. I'm not sure who made that video I found but it was missing a lot of information once I got into it. Make sure it is warm to hot out when you do it so the plastic isn't brittle and breaks. I had to flex the side pieces quite a bit to get them to pop loose from the bracket that bolts to the fender edge. The grill doesn't feel like it wants to let loose either and took quite a bit of tugging. The video made it look like you just pull away from the radiator with both hands and it comes loose. I had to pull from one side to get it loose first then work my way across the fasteners.
There is also a good chance you will break 1 or 2 of those white plastic clips.  You can buy them on amazon for pretty cheap so I would suggest buying a pack of them for a few pennies so that you have them in hand before doing the grill removal.
I didn't break any, but I did find one missing from the factory and another smashed instead of inserted in the hole on the fender side panels.
  • Haha 1
That sucks, lol.  Mine were all inserted properly, but I snapped one upon removal.  I think I got a bag of 100 white plastic clips for like $10 or something if I remember correctly, cheap insurance.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
