If the 1500HD uses a Hydro-boost system, no you can not do that.
Also it's very possible that a non-hydroboost on a HD truck has different lines because the steering gear is different. A 1500HD is really just a standard 2500 light duty truck.
Compare part numbers. If they are different chances are you cannot substitute one for the other.
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 906 Guests (See full list)
