GM offer bug shield as OEM part ? anyone have it on their 2022 gmc1500 post a picture and part number please
Screen Shot 2022-07-17 at 9.36.45 AM.pngedit this is not my truck.
Edited by FJB
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
