no GM replacement available  - used third part (Jasper) plus new axels. After installing , got numerous warnings and lights. ABS, Emergency Brake, Stabilitrack,  - all reset after engine stop
also had uninitiated throttle increase when decelerating ?????
Edited by Kape Kod 1
Updated
Bob, you're going to need to explain your issue more clearly. That would more or less a ramble of words.
