Just bought a k3500 2000 reg cab 4x4 at auction. Gambled for a 454 but got the 350 😪.  Engine is..."lean".. but transmission feels freaking amazing.
Hobbled it home with really bad front wheel bearings but otherwise looks very clean.
Happy to get back into working on these!  Did these forums change? It seems way more sloppy and slow on my phone and hard to navigate through the ads.
I used to frequent the gmt800 side a long time ago but sold my 2002 1500.
probably your phone. Add an ad blocker and that should help. congrats on your new ride, what was the cost?
  • 3 weeks later...
I just picked up mine 2 weeks ago!  Love the C/K trucks. Sold my 19 High Country back. Got great money for it. Fixing this up here and there for a year until
my son turns 14.
Took off the exhaust donut gaskets because they were toast.  Huge leak coming from there.  Broke off one of the manifold bolts, no biggie.  Took both manifolds off to replace the studs and both manifolds had cracks in the center.
Not the end of the world, they looked roasted anyway.  Got the replacements in and hopefully gets the engine somewhat back to normal!
yeah it's pretty common for the manifolds to crack when they get old. The 1s on my 98 are scary rusted as it plowed snow since new but the trans is toasted again for the third time so looking for another truck around the same year
Well found my other engine problem.  Huge exhaust leak was obvious but still threw p0102 etc MAF codes.
started cleaning my grounds along the harness then followed one strand to rear engine block and this ground was disconnected.  Cleaned off the engine block bolt and reconnected, runs pretty good and no codes so far!
glad I replaced the exhaust anyway because I noticed heat was starting to mess with the wiring harnesses
Now on to the wheels, pretty much everything is going to have to go and dreading getting the control arm bushings replaced.  On my gmt800 I just bought new control arms but Im trying to save money on this one.
    Dom Colussi
    Dom Colussi
  • Who's Online   4 Members, 0 Anonymous, 693 Guests (See full list)
