Transmission "service"
MarkD
Totally agree.  If a shop isn't going to change the filter, go to one that will.  The filter is just as important as the flush itself.  The July issue of Corvette Fever has an article on tranny flushing also.
I've seen and done the tranny flush myself and you wouldn't believe the sh*t that comes out!!  I HIGHLY recommend on cars with 50k+ to get a trans flush if they have the means to.  I also wouldn't NOT change the filter.
I'm not an expert, but based on my experiences, I'd say the article was pretty much on the level.  It would make sense, and although may be more expensive to replace the filter in some apps, I say it's cheap insurance, especially with the extended maintenance schedules we have now.
So you use the heavy use schedule and change the filter and flush the tranny every 50K miles?  Still cheaper than a $1,500 tranny.  :thumbs:
CMNTMXR81,
Are you trying to trick me?  I was trying to think why you wouldn't change the filter.(until I read your post again) :thumbs:
I do mine at around 40k, the owner's manual says 50k. A tranny guy at putc reccommended the 40k to me.
My shop does the flush with a filter change. It costs $70.00, but a new tranny cost a lot more...
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,105 Guests (See full list)
